For Android TVs
- Press the HOME button on the Remote and select Settings
- Select Channel set up in the TV category
- Select Digital setup > Digital Tuning (or Satellite setup)
- Select Program List edit (or Satellite Programme List edit.)
- Press the [↓] (Down arrow) or [↑] (Up arrow) button on the remote to search for the corresponding channel name
- Select the corresponding channel name, and press the [→] (Right arrow) button on the remote. The channel name will be highlighted in white, and moved to the right side
- Press the [↓] (Down arrow) or [↑] (Up arrow) button on the remote to move to the previous channel number
For LCD TVs
- On the remote control, press HOME, MENU or the [i+] button
- Navigate to Settings
- Select Digital Program Sorting
- Enter the channel number you want to change the order of (e.g. [032]) and press OK
- Using the UP/DOWN arrows of the remote control, move to the selected channel to a program number of your choice, e.g. [001], and confirm by pressing OK
